CNC Construction Set Build 4 Blog - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: CNC Construction Set Build 4 Blog
  1. #21
    Default Re: CNC Construction Set Build 4 Blog
    Volume 3B - Chapter 11 - Mach3 Install
    Mach3 Installed.
    Volume 3B - Chapter 12 - Mach3 Configure
    Mach3 Configured.
    Volume 3B - Chapter 13 - UC300 Install
    UC300 Installed and configured.
    Volume 3B - Chapter 14 - Motor Cables
    Motor cables installed.
    Volume 3B - Chapter 15 - Motor Setup
    Motors setup.
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  2. #22
    Volume 3B - Chapter 11 - Mach3 Installation
    Mach3 installed.
    Volume 3B - Chapter 12 - Mach3 Configuration
    Mach3 configured.
    Volume 3B - Chapter 13 - UC300 Installation
    UC300 and software installed.
    Motors setup in Mach3.
    Volume 3B - Chapter 16 - Motor Installation
    Motors installed.
    Volume 3B - Chapter 17 - Motor Mount Tuning
    Motors mounts tuned and secured.
    CNC Construction Set Build 4 Blog-_mg_3950-jpg
  3. #23
    Volume 3 Advanced Electronics is now complete.
    I went ahead and installed my drag chain.
    CNC Construction Set Build 4 Blog-_mg_3989-jpg
    After some break-in I will start with the Hypertherm plasma upgrade.
  4. #24
    Volume 5B - Basic Plasma Table (Hypertherm Edition)
    Volume 5B - Chapter 2 - Side Table Supports
    Installed.
    Volume 5B - Chapter 3 - Leveling Table Supports
    Leveled.
    Volume 5B - Chapter 4 - Center Table Support
    Installed and leveled.
    Volume 5B - Chapter 5 - Table Slats
    Installed.
    CNC Construction Set Build 4 Blog-_mg_4066-jpg
    Everything went together as expected. The only thing I would add is to watch the two mounting holes on the center mounting brackets. The book has the hole locations at 5/8" from the outside edge. I think that 11/16" from the outside edge would give you a little more adjustability.
  5. #25
    Volume 5B - Chapter 6 - Downdraft Shelf
    Installed.
    CNC Construction Set Build 4 Blog-_mg_4075-jpg
    Volume 5B - Chapter 7 - Downdraft Side Panels
    Installed.
    CNC Construction Set Build 4 Blog-_mg_4078-jpg
    Volume 5B - Chapter 8 - Downdraft End Panels
    Installed.
    CNC Construction Set Build 4 Blog-_mg_4083-jpg
    I went ahead and installed the exhaust collar as well. You can find that write-up here:
    Downdraft Exhaust Collar — Kronos Robotics
    CNC Construction Set Build 4 Blog-_mg_4082-jpg
  6. #26
    Volume 5B - Chapter 9 - Torch Holders
    Hypertherm machine torch mounted.
    CNC Construction Set Build 4 Blog-_mg_4182-jpg
    I also did some grounding work on the machine.
    CNC Construction Set Build 4 Blog-_mg_4146-jpg
  7. #27
    Volume 5B - Chapter 10 - Hypertherm Control Cable
    Cable complete.
    CNC Construction Set Build 4 Blog-_mg_4236-jpg
    Volume 5B - Chapter 11 - Mounting the Relay
    Relay Mounted.
    Volume 5B - Chapter 12 - Mounting the Terminal Block
    Terminal Block Mounted.
    Volume 5B - Chapter 13 - Cable Hookup
    Cable connected.
    Volume 5B - Chapter 10 - Configuration
    Mach3 configured.
    CNC Construction Set Build 4 Blog-_mg_4273-jpg
  8. #28
    Volume 5B - Chapter 15 - First Test
    Machine tested.
    CNC Construction Set Build 4 Blog-_mg_4257-jpg
    Volume 5B is now complete.
  9. #29
    MikeyS's Avatar
    Jan 2021
    Aluminum is the lightest industrial material for construction, I ask because I am now doing new repairs in an old house. We want to replace the roof with an aluminum roof, but we do not want the roof to weigh many kilograms. Recently changed the parquet and decided to change the roof, helped to install the parquet if anything care homes services. We liked the services and want to change the roof, but for this, you need to choose the material from which the roof will be made. Here I want to know if aluminum is good for our weather conditions, where I heard that it is bad, and in another place, I heard that it is inexpensive and has good characteristics for its cost
