CNC Construction Set Build 3 Blog - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
Thread: CNC Construction Set Build 3 Blog
  1. #41
    Default Re: CNC Construction Set Build 3 Blog
    Volume 5 - Chapter 5 - Table Slats
    Table slats are cut and installed.
    CNC Construction Set Build 3 Blog-_mg_2723-jpg
    The slats are held in-place with standoffs.
    CNC Construction Set Build 3 Blog-slat-jpg
    These standoffs, can be replaced as need as they are considered consumables. This means you can add/move/remove as you see fit. Note that they also become mounting points for fixtures.
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  2. #42
    Volume 5 - Chapter 6 - Downdraft Shelf
    The cement board shelf is installed.
    CNC Construction Set Build 3 Blog-_mg_2904-jpg
    Volume 5 - Chapter 7 - Downdraft Side Panels
    Downdraft sides installed.
    CNC Construction Set Build 3 Blog-_mg_2971-jpg
    Volume 5 - Chapter 8 - Downdraft End Panels
    The end panels have been added. Its time to mount the torch.
    CNC Construction Set Build 3 Blog-_mg_2985-jpg
  3. #43
    Volume 5 - Chapter 9 - Torch Holder
    Everlast IP-60 torch holder installed.
    CNC Construction Set Build 3 Blog-_mg_3121-jpg
    Torch holder parts walk-through.
    Everlast iPT60 Tool Holder — Kronos Robotics
  4. #44
    Heavy Duty Table
    It was at this point that I decided to make a heavy duty aluminum table insert that could be used for milling operations.
    CNC Construction Set Build 3 Blog-_mg_2782-jpg
    These support brackets must be placed so that they fall between the slats.
    CNC Construction Set Build 3 Blog-_mg_2803-jpg
    To further support the table, small bolts or studs can be inserted into some of the standoffs.
    The writeup for this table can be found here:
    https://www.kronosrobotics.com/heavy...aluminum-table
  5. #45
    Volume 5 - Chapter 10 - Everlast Control Cable
    Control cable complete.
    CNC Construction Set Build 3 Blog-_mg_3246-jpg
    With the control cable we can get the following signals from the plasma cutter to the CNC.
    ARC Start
    ARC OK
    Torch Voltage (Divided)
  6. #46
    Volume 5 - Chapter 11 - Mounting the Relay
    I originally was going to use this relay board to start and stop the plasma cutter. But, due to some safety issues with the relays activating while powering up, I decided against the.
    CNC Construction Set Build 3 Blog-_mg_3248-jpg
    I decided on this Omron LY2 style relay. They are easy to replace and there are tons of manufactures that sell them.
    CNC Construction Set Build 3 Blog-_mg_3316-jpg
  7. #47
    Volume 5 - Chapter 13 - Cable Hookup
    Cable connected and wired to the relay and G540.
    CNC Construction Set Build 3 Blog-_mg_3314-jpg
    Volume 5 - Chapter 14 - Configuration
    Mach3 is now configured. At this point we can turn the torch on and off. It's time for a test.
    CNC Construction Set Build 3 Blog-main-jpg
  8. #48
    Volume 5 - Chapter 15 - Torch Test
    Fire that torch.
    Attachment 417196
  9. #49
    Volume 5 - Chapter 16 - Conclusion
    The torch fires perfectly. But before I can actually cut anything we have to get our downdraft up and running. These will be covered in separate articles, that I will link to once they have been posted.
    Volume 5 is now complete
  10. #50
    Air quality is as important as air quantity when it comes to plasma cnc.
    CNC Construction Set Build 3 Blog-plasmatest2-jpg
    I did a write up on the air requirements for the Everlast 50s plasma cutter and the CNCCS.
    See it here:
    Plasma CNC Air Quality
  11. #51
    I added a downdraft exhaust collar to the downdraft enclosure.
    CNC Construction Set Build 3 Blog-_mg_3048-jpg
    See the full write up here:
    Downdraft Exhaust Collar — Kronos Robotics
  12. #52
    I added the downdraft vent to my system.
    CNC Construction Set Build 3 Blog-_mg_3156-jpg
    See the writeup here:
    Downdraft Vent — Kronos Robotics
  13. #53
    I added a some brackets to help with eliminating plasma dust in the shop.
    CNC Construction Set Build 3 Blog-downdraft-assembly-corners-3-jpg
    You can see the full write-up here:
    https://www.kronosrobotics.com/cnccsdust1
