CNC Construction Set Build 3 Blog - Page 5
Page 5 of 5 FirstFirst ... 2345
Results 49 to 53 of 53
Thread: CNC Construction Set Build 3 Blog
  1. #49
    Member msimpson99's Avatar
    Aug 2010
    Default Re: CNC Construction Set Build 3 Blog
    Volume 5 - Chapter 16 - Conclusion
    CNC Construction Set Build 3 Blog-_mg_3121-jpg
    The torch fires perfectly. But before I can actually cut anything we have to get our downdraft up and running. These will be covered in separate articles, that I will link to once they have been posted.
    Volume 5 is now complete
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  2. #50
    Aug 2010
    Air quality is as important as air quantity when it comes to plasma cnc.
    CNC Construction Set Build 3 Blog-plasmatest2-jpg
    I did a write up on the air requirements for the Everlast 50s plasma cutter and the CNCCS.
    See it here:
    Plasma CNC Air Quality
  3. #51
    Aug 2010
    I added a downdraft exhaust collar to the downdraft enclosure.
    CNC Construction Set Build 3 Blog-_mg_3048-jpg
    See the full write up here:
    Downdraft Exhaust Collar — Kronos Robotics
  4. #52
    Aug 2010
    I added the downdraft vent to my system.
    CNC Construction Set Build 3 Blog-_mg_3156-jpg
    See the writeup here:
    Downdraft Vent — Kronos Robotics
  5. #53
    Aug 2010
    I added a some brackets to help with eliminating plasma dust in the shop.
    CNC Construction Set Build 3 Blog-downdraft-assembly-corners-3-jpg
    You can see the full write-up here:
    https://www.kronosrobotics.com/cnccsdust1
