Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
Volume 5 - Chapter 9 - Torch Holder
Everlast IP-60 torch holder installed.
Torch holder parts walk-through.
Everlast iPT60 Tool Holder — Kronos Robotics
Heavy Duty Table
It was at this point that I decided to make a heavy duty aluminum table insert that could be used for milling operations.
These support brackets must be placed so that they fall between the slats.
To further support the table, small bolts or studs can be inserted into some of the standoffs.
The writeup for this table can be found here:
https://www.kronosrobotics.com/heavy...aluminum-table
Volume 5 - Chapter 11 - Mounting the Relay
I originally was going to use this relay board to start and stop the plasma cutter. But, due to some safety issues with the relays activating while powering up, I decided against the.
I decided on this Omron LY2 style relay. They are easy to replace and there are tons of manufactures that sell them.
Volume 5 - Chapter 15 - Torch Test
Fire that torch.
Attachment 417196
Air quality is as important as air quantity when it comes to plasma cnc.
I did a write up on the air requirements for the Everlast 50s plasma cutter and the CNCCS.
See it here:
Plasma CNC Air Quality
I added a downdraft exhaust collar to the downdraft enclosure.
See the full write up here:
Downdraft Exhaust Collar — Kronos Robotics
I added the downdraft vent to my system.
See the writeup here:
Downdraft Vent — Kronos Robotics
I added a some brackets to help with eliminating plasma dust in the shop.
You can see the full write-up here:
https://www.kronosrobotics.com/cnccsdust1
