CNC Construction Set Build 3 Blog - Page 2
Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 53
Thread: CNC Construction Set Build 3 Blog
  1. #21
    Default Re: CNC Construction Set Build 3 Blog
    Volume 2 - Chapter 11 - Z Axis ACME Screw
    Installed the Z axis ACME screw.
    CNC Construction Set Build 3 Blog-_mg_1658-jpg
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  2. #22
    Volume 2 - Chapter 12 - X ACME Screw
    I cut and installed the X axis ACME screw.
    CNC Construction Set Build 3 Blog-_mg_1671-jpg
    Note that I am using the helical shaft couplers. I have found that these work the best for this build.
    CNC Construction Set Build 3 Blog-_mg_1672-jpg
  3. #23
    Volume 2 - Chapter 13 - Z Carriage Install
    Z carriage installed.
    CNC Construction Set Build 3 Blog-_mg_1677-jpg
  4. #24
    Volume 2 - Chapter 14 - Y Axis ACME Screws
    The Y axis ACME screws have been installed.
    CNC Construction Set Build 3 Blog-_mg_1674-jpg
    CNC Construction Set Build 3 Blog-_mg_1673-jpg
    The End of the shaft coupler should be about 1/4" from the rear edged of the mount as shown here.
    CNC Construction Set Build 3 Blog-_mg_1679-jpg
  5. #25
    Volume 2 - Chapter 15 - Conclusion
    It's just about time to get this baby going.
    Volume 2 is now complete.
  6. #26
    Volume 3 - Chapter 1 - Getting Started
    Started getting parts together for the electronics.
    CNC Construction Set Build 3 Blog-_mg_1683-jpg
    Volume 3 - Chapter 2 - Layout Board
    Board completed.
    CNC Construction Set Build 3 Blog-_mg_1684-jpg
    Volume 3 - Chapter 3 - Mounting the Power Supply
    Power Supply Mounted.
    CNC Construction Set Build 3 Blog-_mg_1685-jpg
  7. #27
    Volume 3 - Chapter 4 - Mounting the G540
    G540 Mounted
    CNC Construction Set Build 3 Blog-_mg_1686-jpg
    Volume 3 - Chapter 5 - Terminal Blocks
    Terminal blocks installed.
    CNC Construction Set Build 3 Blog-_mg_1688-jpg
    Volume 3 - Chapter 6 - Wiring
    Wired up.
    CNC Construction Set Build 3 Blog-_mg_1690-jpg
  8. #28
    Volume 3 - Chapter 7 - Mach3 Install
    Mach 3 Installed. Note that I am using an old Windows 7 PC for this. In time it will move to a small form factor Windows 10 PC.
    Attachment 417064
    Volume 3 - Chapter 8 - Mach 3 Config
    Mach 3 Configured.
    CNC Construction Set Build 3 Blog-mach3config-jpg
  9. #29
    Volume 3 - Chapter 9 - UC100 Install
    UC100 Installed and working.
    CNC Construction Set Build 3 Blog-_mg_1691-jpg
    I plan on installing the UC300ETH and configuring it. I will do that after I go through Volume 3 completely so I can iron out any issues in the book.
    A tornado hit our local Amazon distribution center so any thing I order is taking weeks, Once some of the parts needed for the advanced electronics volume finally get here, I will start as I suspect I will have volume 3 testing complete.
  10. #30
    Volume 3 - Chapter 10 - Motor Cables
    Motor Cables Built.
    CNC Construction Set Build 3 Blog-_mg_1693-jpg
    On this build I added rear covers and connectors to the Motors.
    CNC Construction Set Build 3 Blog-_mg_1692-jpg
    While you don't have to add connectors to your motors, I do it because I change things around all the time.
  11. #31
    Volume 3 - Chapter 11 - Motor Setup
    Motors setup in Mach 3.
    CNC Construction Set Build 3 Blog-_mg_1698-jpg
    My layout board is placed on the lower shelf I added earlyer. As this is only an option, you will need to come up with some sort of table to hold the layout board if you did not add this lower shelf.
    CNC Construction Set Build 3 Blog-_mg_1701-jpg
  12. #32
    Volume 3 - Chapter 12 - Installing the Motors
    Volume 3 - Chapter 13 - Motor Tuning
    Motors installed and tuned.
    CNC Construction Set Build 3 Blog-_mg_1710-jpg
    CNC Construction Set Build 3 Blog-_mg_1709-jpg
    CNC Construction Set Build 3 Blog-_mg_1708-jpg
    CNC Construction Set Build 3 Blog-_mg_1707-jpg
  13. #33
    Volume 3 - Chapter 14 - Conclusion
    I did some temporary cable management.
    CNC Construction Set Build 3 Blog-_mg_1714-jpg
    CNC Construction Set Build 3 Blog-_mg_1711-jpg
    Volume 3 is now Complete
    This wraps up the third volume. I have added some content to the CNC Construction Set area on the Kronos Robotics website. I will post links in this blog as I complete them.
  14. #34
    Volume 3B
    I upgraded the machine to advanced Electronics as per the Volume 3B book.
    CNC Construction Set Build 3 Blog-_mg_2394-jpg
    Advanced electronics, while a little more expensive lets you move into some more advanced operations, such as plasma cutting or adding a rotary axis.
    I have added a drag chain upgrade and mounted the layout board to the machine.
    You can find the upgrades here:
    CNC Construction Set Upgrades
    Accessory Brackets
    CNC Construction Set Build 3 Blog-_mg_2334-jpg
    Writeup here:
    https://www.kronosrobotics.com/cnccsaccessorybrackets
    Mounting the Layout Board
    CNC Construction Set Build 3 Blog-krccs-full-assembly-v4-layout-board-9-a
    Writeup here:
    https://www.kronosrobotics.com/cnccslayoutboard
    Cable Management
    CNC Construction Set Build 3 Blog-_mg_2472b-jpg
    Write up here:
    https://www.kronosrobotics.com/cnccscablemanagement/
  15. #35
    Machine Break-in
    It't time to do some break-in on the new machine.
    I did a writeup on my break-in procedure here:
    CNCCS Breakin
  16. #36
    Basic CNC Tables
    I did a writeup on adding various table types to the CNCCS.
    You can find it here:
    https://www.kronosrobotics.com/cnccstables1
    Here I am using one of the tables to do a drawing test.
  17. #37
    Router Mount
    I added a CNCRouterParts router mount to the build.
    CNC Construction Set Build 3 Blog-_mg_2026-jpg
    This means you can use any of several spindles or routers with the CNCCS (CNC Construction Set)
    See my writeup here:
    https://www.kronosrobotics.com/cnccsroutermount
  18. #38
    Z axis bearing mount brace
    A small brace to keep the Z bearing mount.
    CNC Construction Set Build 3 Blog-_mg_2493-jpg
    Writeup here:
    https://www.kronosrobotics.com/cnccszbrace
  19. #39
    At this point this point, I will start the plasma table upgrades for the CNCCS (CNC Construction Set) build. This upgrade will allow me to perform CNC plasma cutting operations. I can still add clamp tables and spindle/router carriages to perform milling operations.
    CNC Construction Set Build 3 Blog-_mg_3420-jpg
  20. #40
    Volume 5 - Chapter 2 - Side Table Supports
    Side supports installed.
    CNC Construction Set Build 3 Blog-_mg_2611-jpg
    Volume 5 - Chapter 3 - Leveling Table Supports
    Supports leveled.
    CNC Construction Set Build 3 Blog-_mg_2679-jpg
    Volume 5 - Chapter 4 - Center Support
    Center support installed and leveled.
    CNC Construction Set Build 3 Blog-_mg_2697-jpg
