Problem Cant find router mounts for the KRMx01
Results 1 to 12 of 12
Thread: Cant find router mounts for the KRMx01
    Feb 2015
    United States of America
    Unhappy Cant find router mounts for the KRMx01
    Hello again
    I am having a heck of a time finding router mounts. K2CNC is of no help, (are they still in business? I can't even get the site to load), as is anywhere else I have searched been fruitless in locating a mount for any one of the 3 routers listed in the KRMx01 book. Is it going to be an issue of buying any fixed base router and having a machine shop make a mount and hope for the best? Buy a spindle w/mount and controller? I don't know.
    Does anyone have any recommendations, suggestions? I want what is best for the KRMx01 CNC machine. I found all three routers listed in the build book, on ebay, but can't find the necessary mounts anywhere.
    While searching on ebay I found some air cooled and water cooled 400W to 2.2kW spindles with mounts and PWM controllers that are supposed to work with Mach3 or a potentiometer if you don't want Mach3 to control the speed . Can something like these be used? Here is a link to one of the 400 watt spindles: CNC 400W Spindle Motor ER11 Mach3 PWM Speed Controller Mount Engraving Set | eBay
    I really don't know if the 400W has enough umph. I don't think I want to mess with anything water cooled as it sound like a real pain. I need help please.
    I am very new to all of this and really don't know what I need. All I know is I can't find what the book calls for and that's why I am here. You guys on this forum have been a great help so far and I have faith you will steer me in the right direction.
    Thanks in advance for all of the help...
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Cant find router mounts for the KRMx01
    UCCNC 2017 Screenset
    Feb 2015
    Awesome! Which router do you recommend? The Bosch 1617 or the Hitachi M12VC? I believe the Hitachi is the one used in the build and is a little less expensive...
    Mar 2003
    Shelby Township
    I've never used either, but I think the Bosch is a little better. Ton's of people use the Hitachi, though.
    Feb 2015
    Thank you very much for your help! I think I will go with the Hitachi as that is the one that was used in the book.
    Mar 2006
    Don't know what is going on with k2cnc.com, but they do have a facebook page. Maybe you can contact them that way. I done a whois on the domain and it does not expire till 2018. When doing an nslookup I get a server error. So either they no longer have a web page, or their provider is down.
    Joe
  7. #7
    K2CNC can be problematic these days.
    Try Velox CNC, they sell the same mounts.
    veloxcncrouters
    Here is the link to the Hitachi mount
    http://veloxcnc.com/proddetail.asp?prod=RM-Hitachi
    Author of: The CNC Construction Set Books, the KRMx01, KRMx02, KRmc01, and KRmf70 CNC Books, the HANS Electric gear clock book. All available at www.kronosrobotics.com.
  8. #8
    Others have reported that the CNCRouter.com mounts work as well. In any case post your results back so others can benefit,
  9. #9
    May 2016
    I'm building a KRMx01 and here's the mount that I ordered for mine today: VeloxCNC (forum removed the link to it)
    They sent me the STEP file and by the measurements there, it should bolt right up to the KRMx01 Z Plate.
  10. #10
    Thanks for the info. Post some pics when you get a chance.
  11. #11
    May 2016
    Quote Originally Posted by msimpson99 View Post
    Will do. I think I will just start a new thread and post pics of my build there. I didn't keep an excellent record like Joe at MyHeap.com did, but his site was my inspiration for building the KRMx01 as my first build.
  12. #12
    I can confirm that the CNCRouterParts mounts work just fine with the KRMx01. Purchase just the mount (minus the adapter plate) and it will bolt directly to the KRMx01 Z-plate. I have a write up for the KRMx02 here:
    CNC Router Parts Router Mounts — Kronos Robotics
