Dyna Mechtronics cnc Knee Mill need help with control
Results 1 to 11 of 11
Thread: Dyna Mechtronics cnc Knee Mill need help with control
    Registered wisp's Avatar
    Mar 2004
    Default Dyna Mechtronics cnc Knee Mill need help with control
    Hi all, I have a 1996 Dyna Mechtronics cnc Knee mill, model EM3116. I want to edit the system parameters and slow down the maximum rapid traverse rate, but the manual says you must contact a dealer to get the password, or procedure to enable editing sytem parameters. I can not get the dyna people to tell me.
    Does anyone know how to get into the system paramters? The control is PC based. There is a pentium 100mhz board, and 500meg HD inside the machine. Here is a link to the machine info....
    EM3116
    Thanks!
    Mar 2004
    I've found out how to change the system parameters on the control. If anyone needs the procedure, let me know.
    Jun 2008
    Mexico
    Hello, I have a problems for to recharge parameters in DM4322, I think it is similar to your control, and I don't have the procedure for to do this, could you help me please, I need the procedure for changing System parameters...
    Gold Member
    Oct 2005
    Procedure depends on which version of the 4M software you are running. V1.4? V2.0?
    Jun 2008
    Mexico
    The version is 2.21
    Dyna 4M CNC Versión 2.21 1999
    And the machine is a Vertical Machining Center DM4322
    Gold Member
    Oct 2005
    The enter system password for 4M:
    - From the program list screen, highlight either of the "arrow" buttons in the upper right of the display. Cursor up once to un-highlight and press the INPUT/ENTER key on the keypad. This will bring up the password entry box.
    - There are scrambled numbers at the top of the box. Ignore the first two characters and enter MKC=xxxx where xxxx is the 3rd, 4th, 5th, & 6th characters in the scrambled numbers at the top of the box. So if the box shows 1G1246H728..., enter MKC=1246 and press INPUT/ENTER. Nothing will show while you are typing the password in.
    - Screen will change if successful. Press ESC to return to program lit screen, then proceed to Parameters. Some system parameters require power off/on to take effect.
  7. #7
    Jun 2008
    Mexico
    Ok thanks I will to try and I tell you what happend, but the box that you say is the box of the operation panel or the electrical box???
  8. #8
    Gold Member
    Oct 2005
    Password entry box means pop up window to enter password.
  9. #9
    Aug 2011
    pakistan
    this is the procedure to change the paramets
    SYSTEM PASSWORD ACCESS PROCEDURE FOR SOFTWARE VERSIONS 2.0/2.2/2.21/2.31/2.32/2.42D
    1.- POWER ON THE MACHINE.
    2.- PRESS MON/MENU BUTTON.
    3.- PRESS ESC BUTTON.
    4.- PRESS F5 BUTTON ( PARA )
    YOUR SCREEN WILL DISPLAY THE G53~G59 COORDINATES AND THE STATUS MENU BAR
    ON THE LOWER LEFT SIDE OF THE SCREEN WILL BE HIGHLIGHTED.
    5.- PRESS THE CURSOR ARROW BUTTON TO THE LEFT <.
    THE STATUS MENU BAR WILL NO LONGER BE HIGHLIGHTED
    THE EMPTY BAR ON THE RIGHT SIDE WILL BE THE ONE HIGHLIGHTED.
    6.- PRESS THE CURSOR ARROW BUTTON DOWN.
    THERE WILL BE NO MENU BARS OR ANYTHING ELSE ON THE SCREEN HIGHLIGHTED.
    7.- PRESS THE INPUT BUTTON.
    AT THIS TIME A DIALOG BOX WILL APPEAR SHOWING A STRING OF 12 CHARACTERS.
    NOTE : STEP #7 WILL SHOW YOU THE STRING OF 12 CHARACTERS.
    PLEASE LET US KNOW THIS NUMBERS THEN WE CAN PROVIDE THE RELEASE NUMBER
    TO GET RIDD OFF THE E435 ALARM.THIS ONLY APPLIES TO THE VERSION 2.31
    7.- PRESS THE LETTER F BUTTON FOUR TIMES AND THEN THE FOUR NUMBERS FROM THE DIALOG BOX
    e.g.:THE DIALOG BOX WILL HAVE THE TOTAL OF 12 CHARACTERS.TAKE THE
    FOUR NUMBERS AFTER THE FIRST TWO DIGITS. FOR EXAMPLE.: QX1014XXXXXX
    THEN THE EIGHT DIGIT PASSWORD WILL BE:FFFF1014 THIS IS ONLY AN EXAMPLE.
    THE ACTUAL NUMBERS ON YOUR CONTROLLER WILL BE DIFFERENT.
    PLEASE MAKE SURE YOU PRESS THE BUTTONS, OTHERWISE YOU WILL HAVE TO
    PRESS THE INPUT BUTTON AND START AGAIN.
    ONCE YOU HAVE ENTERED THE PASSWORD.GO TO THE NEXT STEP ( 8 )
    8.-PRESS THE INPUT BUTTON.,IF THE EIGHT DIGIT PASSWORD HAS BEEN ENTERED
    CORRECTLY THE SCREEN WILL CHANGE AND GO TO THE SYSTEM PARAMETER PAGE 1/3
    THIS WILL ALLOW YOU TO MAKE ALL NECESSARY MODIFICATIONS
    OR CHANGES TO THE 4M SYSTEM PARAMETERS.
    PLEASE WRITE DOWN OR RECORD THE OLD PARAMETERS BEFORE YOU MAKE ANY CHANGES
    JUST IN CASE YOU NEED TO GET THE MACHINE BACK TO THE WAY IT WAS.!!!!!!!!!!!
  10. #10
    Aug 2011
    pakistan
    Default DYNA Em3116 Manuals
    any one have dyna em3116 manuals...i need it...plz contact me my yahoo id is adnan_pucit48@yahoo.com...
  11. #11
    Default Re: Dyna Mechtronics cnc Knee Mill need help with control
    any one have dyna DM4322 manuals...i need it...plz contact me Eng.ibraheemkhress@gmail.com
  12. #12
    juliorosales's Avatar
    Sep 2019
    alguien quien pueda retomar el tema?
