No backlash adjustment screw on feed nut bracket(yoke)
Results 1 to 5 of 5
Thread: No backlash adjustment screw on feed nut bracket(yoke)
    Member Sup3rfly's Avatar
    Jan 2021
    Default No backlash adjustment screw on feed nut bracket(yoke)
    I have a supermax ycm1 1/2 va and somehow the feed needs (2 nut design) came out of the bracket so I removed the table and lead screw to feed the assembly back into it but noticed there were no adjustment screws at all not even a tapped hole for an adjustment screw to go into. The bracket does however have a boss where it looks like the screw would normally go. Is there some other mean of adjusting the backlash on these machines?
    Feb 2008
    Default Re: No backlash adjustment screw on feed nut bracket(yoke)
    Do you have a picture?
    Sent from my 5007U using Tapatalk
    Feb 2008
    You could make a shim stock washer under I of them, then reinstall it.
    It will take a bit of fiddling to find the right thicknesses, and will depend if you screw is worn in the centre.
    Or just add the slots in the nut yourself, only 1 needs to be done.
    If you don't have a rotary table, the slots could be marked out and filed out, as it's only Bronze.
    Jan 2021
    Quote Originally Posted by Davo J View Post
    Hope the pics showed up.
    If they did well that’s the exact bracket I believe I have. I don’t think it’s the original.
    I’m leaning towards slapping the yoke on a drill press. Scary thought however.
    Side note: how do the nuts in the supplied pic work as far as adjustment goes?
    Attached Thumbnails Attached Thumbnails No backlash adjustment screw on feed nut bracket(yoke)-cd3df189-3db6-4e2f-ac78-89aa689515c2-jpg   No backlash adjustment screw on feed nut bracket(yoke)-8ac11bec-e49c-4284-aa5c-8f6d17585666-jpg
    Jan 2021
    Davi J attached pics of the bracket I have in the reply above this one. Have a gander. Of course with out those actual feed nuts. I have split nuts.
