- Need Help!- retrofit a cincinnatti toolmaster mt (the french model)
hi every one,
well recently i've bought a toolmaster mt came with a hydrolic true trace 3d, and i wish to retrofit, i have some 10 nm closed loop steppers and a 32 mm dia ballscrew with 5 mm pitch, any ideas i'll appreciat your help.
i'm willing to remove the knee acme lead screw and replace with the BS is it good or a bad idea
in atachement some early photoes
thanks
- You may not post replies
- You may not edit your posts
Forum Rules
