- Anilam Crusader M X-Axis Chirp
I have an Anilam Crusader M 3 axis milling machine that has ran great. Yesterday, after about 8 hours of machining, the x-axis started to chirp. It sounded like a harmonic chirp coming from the servo motor side of the table. This only happens when the machine is not moving and is sitting still with the servos turned on. It rapids fine and does not make the sound when in motion. I also checked it to make sure it still held position over the travel of the table and that was fine also.
Anyone else ever experience this or have any idea what it may be?
Thanks,
Steve in Indy
- You may not post replies
- You may not edit your posts
Forum Rules
