You are looking for a large transformer, maybe. The should be a large capacitor(s) somewhere, and a bridge rectifier. The bridge rectifier should be connected to a transformer output by black wires, the output from the bridge rectifier may be Orange (+) and Gray (-) wires, those should be connected to a large capacitor with a large resistor across it. The supply voltage can be measured across the capacitor, it will be a DC voltage around 140 VDC. It is possible that the drive PS is direct from the line, but not likely.
