Interesting. If anyone can help me with a similar problem, described here, please do.
https://www.cnczone.com/forums/fanuc...tem-ready.html
I have an Enshu Yuasa AccuMill 1547 with Fanuc 3M. It has worked well for years. The last time I powered it up, I got a not ready message on the controller. I was able to get the machine to move in all axis by holding the limit release switch but only in the - direction. I am not hearing the normal sounds I hear on start up.
There are no blown fuses, no apparent relay issues, or anything that jumps out saying this is the problem.
Please help if you can.
Ed
Ed
