Need Help! Shizuoka
Results 1 to 2 of 2
Thread: Shizuoka
    Jul 2004
    Default Shizuoka
    I have a Shizuoka milling machine. It was built in the mid 70's, CNC, variable belt, nmtb 40, knee, 3HP.
    Can anyone describe in detail how to change the belt. I presume the spring on the pulley must be compressed and removed, but how?
    I'm told that other machines have small screw holes in the spring ring that accommodate spring compression. This machine has no such holes.
    Thanks,
    Ozzie
    Feb 2018
    Default Re: Shizuoka
    Is this machine a Shizuoka Millmaster B3-v? Do you happen to have the owners manual
    Thank you
    Nic
Shizuoka
Shizuoka
