Build Thread King Rich KRV-2000 Knee Mill CNC Conversion - Page 11
Page 11 of 11 FirstFirst ... 891011
Results 201 to 207 of 207
Thread: King Rich KRV-2000 Knee Mill CNC Conversion
  1. #201
    Sep 2008
    Default Re: King Rich KRV-2000 Knee Mill CNC Conversion
    New project to make a Mill Riser Block out of a piece of hydraulic cylinder 406 O.D. 340 I.D and 216mm long. It was bandsawn from a barrel 3.7m long that weighed 1300kg. This piece alone is around 75kg. A Mill riser block fits on top of the column and raises the turret 200mm to allow more clearance between the spindle and the table for larger jobs like boring a small engine or drilling with a long drill bit or tapping with a tapping head or working over a large rotary table or vise.
    They can be purchased for a Bridgeport secondhand for a reasonable price but the King Rich is a bit larger and very expensive. Access to a piece of stock like this made the project viable to build one..
  2. #202
    Sep 2008
    I needed to register the Riser Block to both the Column and the Turret.
    Attached Thumbnails Attached Thumbnails King Rich KRV-2000 Knee Mill CNC Conversion-20191209_130017-1024x576-jpg   King Rich KRV-2000 Knee Mill CNC Conversion-20200417_162539-1024x576-jpg   King Rich KRV-2000 Knee Mill CNC Conversion-20200417_162633-1024x576-jpg
  3. #203
    Sep 2008
    After sorting out a method of registering the riser block, the turret was lowered back into position and the head was trammed so I could continue machining.
  4. #204
    Sep 2008
    The tram is good but the surface finish can be improved by changing the tool path exit and including a spring pass.
  5. #205
    Sep 2008
    When I was happy with the surface finish on the first side, the riser block was flipped over and the rough sawn second side was machined flat.
  6. #206
    Sep 2008
    Installation required the 70kg riser block to be transfered from the table to the column.
    Attached Thumbnails Attached Thumbnails King Rich KRV-2000 Knee Mill CNC Conversion-20200420_163626-605x1024-jpg
  7. #207
    Sep 2008
    The 14 inch long 5/8 UNC hold down bolts had 15/16" AF hex heads. The original 6 inch bolts have 23mm AF heads which match the supplied ring spanners in the Mill Tool Kit.
    Attached Thumbnails Attached Thumbnails King Rich KRV-2000 Knee Mill CNC Conversion-20200109_200526-1024x576-jpg   King Rich KRV-2000 Knee Mill CNC Conversion-20191209_125327-1024x576-jpg   King Rich KRV-2000 Knee Mill CNC Conversion-uncvswhitworthnot-1024x587-jpg   King Rich KRV-2000 Knee Mill CNC Conversion-20200421_172513-720x1280-jpg
