Removing play in Z axis
Results 1 to 3 of 3
Thread: Removing play in Z axis
    Member 5Carbides's Avatar
    Nov 2019
    Default Removing play in Z axis
    What is the intended way to adjust the bearing side-to-side for the Z axis? I have a a lot of play https://sendvid.com/6cq50f94
    I tried loosing the bolts holding the bearings on to see if there way movement in their holes and I could just move them over and tighten them, but there was none. My only guess at this point is to shim out the vertical metal rails that the bearings ride in.
    I am hoping a Joe's builder can provided some insight. I am a 3rd owner of this fairly well built Joe's machine.
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Removing play in Z axis
    The bearings on one side should be on eccentric bushings that you turn to tighten.
    The angle iron isn't helping. Switching to precision rail would help, but you'll always have some play with that system.
    UCCNC 2017 Screenset
    Nov 2019
    Yes there were eccentric bearings on the one side. Thank you.
    Adjustment of these help resolved play as well as binding that was taking place when the Z axis moved up.
