Rack vs lead screw
Results 1 to 3 of 3
Thread: Rack vs lead screw
    Feb 2018
    New Zealand
    Default Rack vs lead screw
    Hi
    I'm looking at either building a Joe's Evo or Hybrid at 4' x 4', it will be made of aluminium and steel (not MDF). I don't as yet, have the plans.
    However, I have this desire (illogical possibly) to use lead screws, not racks. Mostly as it looks more straight forward and a bit cheaper.
    I assume I can connect the screws directly to the stepper, avoiding belts, tensioner pullys etc...
    So, are the racks that much better?
    It's going to be a hobby machine and I might drive it hard sometimes, but not on a daily basis.
    thanks
    Patrick
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: Rack vs lead screw
    If you purchase the plans, and get access to the forum, you'll see that almost all of the newer builds use rack and pinion, and many of the early leadscrew machines have been converted. Rach and pinion is much more efficient than acme leadscrews, and will give 2-3x better performance.
    If you want to use screw drive, then you'd want to use 20-25mm diameter screws with a 10-25mm pitch.
    UCCNC 2017 Screenset
    Feb 2017
    Turkey
    Ofcourase lead screws are less efficient in class. Only advantage is that it is self locked. Ball screws are good choice,
Rack vs lead screw
Rack vs lead screw
