Two more of Joe's CNC Model 2006 - Page 9
Page 9 of 9 FirstFirst ... 6789
Results 161 to 168 of 168
Thread: Two more of Joe's CNC Model 2006
  1. #161
    Registered GAWnCA's Avatar
    Oct 2005
    Quote Originally Posted by Buzz9075 View Post
    Mine is collecting dust because of all the issues I had with it :0 as well as 10K was to slow for some work, and the noise levels are much lower without in on. Thinking about selling it and the adaptors.
    What kind of router are you running? What all do you have and how much?
  2. #162
    Dec 2006
    Not sure what I want.... I have many adaptors, the drill bit adaptor with head. I will gather all the information in tonight and post. Here is a list of the issues I have had (with the stronger spring).
    Dust collects between the head and the adaptors, making if very hard to remove the adaptor till you get the dust out.
    Even at 10K to 12K (as many have proved you can run), the adaptors will spin in the head unit when a high strees zone is hit (really obvious in oak with the grain gets tight). This cause a side effect of removing the finish of the cutters.
    For some reason I can not longer get the V cutters to spin true when using it true
    Noise level from the router is much higher with the attachment in versus out. My house is much quiter running the router without it in.
  3. #163
    Jun 2007
    Kingdom of Sweden
    Greetings.
    I have been following the thread about the tool changer in silence.
    I am planning to build a CNC mill and would love to have a tool changer.
    Can I also get a copy of the plans, please?
    fruktodlaren(a)gmail.com
    Best regards
    /Tony from Sweden
    Last edited by Ghostpilot; 01-14-2008 at 03:54 PM. Reason: Spelling in Swedish English... Wait... SWEnglish.
  4. #164
    Dec 2006
    I have uploaded the information on the tool changer I am going to sell on my web page... once the information is gone the unit is sold... www.cncmachine.phillipsfamily.ca
  5. #165
    May 2014
    Spain
    Default Re: Two more of Joe's CNC Model 2006
    good job
    Where can I buy this rapid changer tool?
  6. #166
    May 2014
    Spain
    where can i buy this rapid changer tool?
  7. #167
    *Registered User* udonnoo's Avatar
    Jan 2019
    hi is there an update about the tool changer
  8. #168
    May 2005
    HiTech systems no longer make the adaptor the changer used so you would need to find another system.
