Here is the gantry together and Like (Lionclaw's suggestion) I will be installing 4 threaded rods all the wat through it left to right. The Z-Axis slide is just a little tight so i need to adjust it a little. (maybe hollow out the bearings ever so slightly). Total weight 77lbs right now and it is pretty well balanced just slightly more to the rear.
