- jgro build questions
I'll answer you questions to best of my knowledge
1. I haven't cut aluminium with my machine but i don't think among hobbycnc, xylotex etc should have a problem with it, the main issue i think you'll get is that the machine isn't really sturdy for that purpose, but as i said, i've never cut alu on mine.
2. A grinder or sander should do the trick, setting it up in a jig to gain the desired results, take a look here for an example post #120: http://www.cnczone.com/forums/showth...=29024&page=10
3. The cutting board is used as the nut tensioners, they are drilled and tapped.
4. With drilling of these holes you should try to take the time to do this carefully, if you're not using a drill press, (which is highly recommended) you should mark them properly and maybe use a smaller drill bit to start a pilot hole first, maybe even using a block of wood with a stop to use as a jig for drilling the pilot holes.
And as for searching in this forum, i have not got that down pat as yet, so sorry can't help you there chap, but good luck on your build, and i think for now the best thing to do is read up on as much as you can, you'd be surprise what you can find in here.
I have cut some aluminium with my JGRO, it requires a sharp bit and a starting feed rate of about 10-20 ipm with a pass depth of about 1/32 to 1/16depending on how sturdy you macine is constructed. You may use a little oil as coolant.
Jason
ty tajord and jason for the replies my brother wants me to make him a wrestling belt when i finish everything and get everything going dont know what there made of actually....i redid the angle iron and it came out way better the only thing is that one bearing is a bit off not by much but it does make the z axis platform move to the right just a bit but other then that everything else is fine ohhh and thanks for the link to that page havent checked it out yet but i will
- You may not post replies
- You may not edit your posts
Forum Rules
