New Machine Build With Modifacations in Steel and Aluminum.
Results 1 to 7 of 7
Thread: With Modifacations in Steel and Aluminum.
    Registered captainlee's Avatar
    Oct 2007
    us
    Default With Modifacations in Steel and Aluminum.
    JGRO MODIFICATIONS IN STEEL AND ALUMINUM.
    I am using 1 1/2" angle for the base and 3/4 " angle for the middle supports.
    Instead of using 3/4 mdf I am using double sided aluminum plywood 1/2 " ( $130.00 per sheet 4x8' ) I will use steel brackets in some places to make up for the lost 1/4 " when using 1/2 plywood instead of 3/4..The rail adjusters are made from 1/2 " aluminum plate. I am going to change from head screws to set or grub screws on the rail adjusters.
    Please do not copy any design changes I have made until I have verified that all my modifications will actually work as made, Thanks
    Some times you have to back and change stuff...:
    Here are some photos of the build so far.
    With Modifacations in Steel and Aluminum.-013-jpgWith Modifacations in Steel and Aluminum.-006-jpgWith Modifacations in Steel and Aluminum.-005-jpgAttachment 333668With Modifacations in Steel and Aluminum.-014-jpgWith Modifacations in Steel and Aluminum.-015-jpg
    Attached Thumbnails Attached Thumbnails With Modifacations in Steel and Aluminum.-011-jpg
    Don't Give Up The Ship !!!
    Oct 2007
    us
    Default Re: With Modifacations in Steel and Aluminum.
    Here are some new photos.With Modifacations in Steel and Aluminum.-001-jpgWith Modifacations in Steel and Aluminum.-002-jpgWith Modifacations in Steel and Aluminum.-003-jpg
    Oct 2007
    us
    Latest mods and parts.
    With Modifacations in Steel and Aluminum.-001-jpgWith Modifacations in Steel and Aluminum.-009-jpgWith Modifacations in Steel and Aluminum.-011-jpg
    Oct 2007
    us
    With Modifacations in Steel and Aluminum.-009-jpgWith Modifacations in Steel and Aluminum.-012-jpgLatest updates on this build.
    With Modifacations in Steel and Aluminum.-006-jpgWith Modifacations in Steel and Aluminum.-002-jpgWith Modifacations in Steel and Aluminum.-001-jpgWith Modifacations in Steel and Aluminum.-004-jpg
    Oct 2007
    us
    Latest parts...With Modifacations in Steel and Aluminum.-001-jpgWith Modifacations in Steel and Aluminum.-005-jpg
    Oct 2007
    us
    More updatesWith Modifacations in Steel and Aluminum.-020-jpgWith Modifacations in Steel and Aluminum.-013-jpgWith Modifacations in Steel and Aluminum.-018-jpgWith Modifacations in Steel and Aluminum.-002-jpgWith Modifacations in Steel and Aluminum.-001-jpgWith Modifacations in Steel and Aluminum.-004-jpg
  7. #7
    Oct 2007
    us
    final photosWith Modifacations in Steel and Aluminum.-019-jpg
  8. #8
    Adam90Haynes's Avatar
    Feb 2021
    Thanks a lot for this post
