pics of my turbine - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 83 of 83
Thread: pics of my turbine
  1. #73
    Jan 2004
    Thanks Ken, had some time to mess around on the cad thought it would be a nice touch. I've kind of stalled with this project, trying to get the rest of the parts together. Then maybe I could post a short video and explanation of the process.
    Regards,
    Greg
  2. #74
    Nov 2003
    Vancouver, B.C.
    Here's a web site you might find interesting.
    http://freespace.virgin.net/cool.stu...gasturbine.htm
  3. #75
    Nov 2003
    Vancouver, B.C.
    And here's where you can get the cast turbine and compressor wheels and other parts.
    http://www.artesjet.com/
  4. #76
    Dec 2004
    england
    Hi gv71
    Your turbine is a kamps/kj66 hybrid could you please explain the hybrid .I am building a Kamps and have just been given some kj66 drawings as I find the detail better on the kj66 drawing. I have built the front end but am not having much sucess with the metal spinning.
    Tony
  5. #77
    Jan 2004
    Tony,
    Basically its a kamps compressor and turbine wheels, shaft and ngv. KJ parts are comb. chamber, fuel ring and outer case. I made dies instead of spinning the parts.
    Greg
  6. #78
    Dec 2004
    england
    Greg,
    Thanks for the reply,I picked up a outer case today and will proceed on the same lines. I will buy a turbine wheel as I have only just finnished my cnc mill and I am learning how to program it.Thanks again.
    Tony
  7. #79
    Jan 2007
    indonesia
    do you guys have a kj66 compressor wheels design..? im desperately needed.. i lost mine.. please.. cause i try to redesign the compressor flow..
  8. #80
    Jul 2008
    South Africa
    Hi Greg, I would really like to get more info from you on how you milled the turbine wheel - I am building a smaller model (Dia 48mm) turbine and would like to know how did you mille the blade profile?
  9. #81
    Oct 2006
    south africa
    so what did you punch the holes?
  10. #82
    Oct 2011
    Default WOULD YOU PART WITH THE CAD
    WOULD YOU PART WITH THE CAD - LOOKING TO CREATE A TURBINE - THIS WILL BE A GOOD START - WILL NEED TO CHANGE SHAFT SIZE ECT...
    THANKS
    ERIC
    CALL OR TEXT
    845-406-7831
    Quote Originally Posted by gv71 View Post
    WOW I was just rying to get things rolling here. Thanks for all the nice comments. I drew the blade profile in cad and then with a 1/8 in. carbide em (used 4 of them) profiled each blade 20 of them taking .015 depth of cut for a total of .400 deep using a manual indexer rotating every 18 degrees. Probably not this one but the next one I build (in the works) which is a little smaller it has a 54 mm dia. turbine wheel where this one is around 66 mm will be going into an RC jet. Here are sompics of the turbine wheel and of a diffuser that I was milling out with my homemade mill.
    Greg
  11. #83
    Nov 2012
    United Kingdom
    nice job. i love all these pictures. thanks for sharing these pictures.all are great models.
    Adam smith
    adam.smith402@hotmail.com
    Nitrotek.se
pics of my turbine
pics of my turbine
pics of my turbine
