- Need Help!- Building a model jet engine
Hi guys, this is my second attempt to built a successful model jet engine , and have some critical questions about that.
I attached some photos from my first attempt below if you want to take a look at. I believe that the engine was too small to self sustain, also i maid the turbine out of steel so it melted at the first start attempt :-( .
Now am trying to built a model jet engine based on an old compressor from a car the size is 66mm.
My questions are:
1) How mach critical is the gap between the compressor its cover?
2) Am trying to built the turbine out of stainless steel, I want to know if it is good enough to stand the high temperatures.
3) What ball bearings I should use?
Thank you very mach.
Re: Building a model jet engine
Also I will try to make some videos on my process, Go to the link below if you interested on that. Any advises would be helpful.
- You may not post replies
- You may not edit your posts
Forum Rules
