- anyone use a "tesla valvular conduit" for a pulse jet?
Seems like the valve is perfect for something like a pulse jet since it allows a flow in 1 direction easily with alot of resistance the other way. Not sure if its effective as the valve design gets bigger but many small ones could be slapped together to allow more air flow. Then again more stages could be added to a larger valve to increase the backwards resistance to flow but that increases the length of the valve more.
- You may not post replies
- You may not edit your posts
Forum Rules
