TRAUB TND 300 two subsystems selected
Results 1 to 3 of 3
Thread: TRAUB TND 300 two subsystems selected
    Jun 2016
    Hungary
    Default TRAUB TND 300 two subsystems selected
    We have TRAUB TND 300 CNC lathe (2 axis) with System TX8 controller.The following problem has occurred:
    At start-up in the morning, the Part 2 system button on the control panel illuminated. So far, No. 1 has always been lit. For some reason, we can’t get out of No. 2. The keyboard works, but Even if I press the button, it doesn't turn it off.
    Can a parameter loss be the cause? How do I turn off System 2?
    Thank you in advance for your response
    TRAUB TND 300 two subsystems selected-screenshot_20211102-121320_chrome-jpgTRAUB TND 300 two subsystems selected-screenshot_20211102-121348_chrome-jpgTRAUB TND 300 two subsystems selected-screenshot_20211102-121411_chrome-jpg
    Attached Thumbnails Attached Thumbnails TRAUB TND 300 two subsystems selected-screenshot_20211102-121320_chrome-jpg   TRAUB TND 300 two subsystems selected-screenshot_20211102-121348_chrome-jpg   TRAUB TND 300 two subsystems selected-screenshot_20211102-121411_chrome-jpg
    Member l1o4's Avatar
    Aug 2022
    Default Re: TRAUB TND 300 two subsystems selected
    how did you solve the problem?
    Jun 2016
    Hungary
    The problem still hasn't been solved. The machine does not work because of the error.
