SCARA Index MS18 MS32 MS52
Results 1 to 3 of 3
Thread: SCARA Index MS18 MS32 MS52
    Registered ag-cnc's Avatar
    Mar 2011
    Herbrechtingen
    Hello
    What could be the reason that the SCARA cancels after every cycle stop?
    Best wishes
    InTex's Avatar
    Feb 2007
    Schladen / Harz
    Hello I can’t quite follow your question.
    Maybe you explain what example you mean
    Eine Schraube ohne Gewinde ist ein Nagel<br /><br />Grüsse aus dem Harz - InTex<br />
    Registered ringspan's Avatar
    Feb 2008
    Auenwald
    Hello
    In the area of a few 1/100mm it’s normal that the axis go out of control at the cycle stop.
    But it’s no problem because usually at the start of the program, the spindle middle is approached with the swiveling cycles.
    The SCARA axis regulates itself immediately and stays in control until the next cycle stop.
    Best wishes
