C200 and entering of comments
Results 1 to 7 of 7
Thread: C200 and entering of comments
    Registered rgmviper's Avatar
    Apr 2007
    Sundern
    Thumbs up
    Hello,
    We have 3 machines with the old c200 controllers from index: one gs30, one gs42 and one gs65. There’re full alphabet and brackets for comments on the keypad.
    So how can I write comments in a program?
    For example:
    T1212 L999 (stop)
    Is there a particular keys combination therefore?
    As a skilled programmer I’m used to comments.
    Additionally I’m searching for a boring cycle for chip breaking.
    I help myself with the deep boring cycle L98 now.
    Thanks in advance.
    Registered wimu's Avatar
    Nov 2004
    72581 Dettingen
    Hello
    I also have these controllers. So far I know you can’t write these texts at the machine.
    I write my texts in the programming space during compiling.
    They are input then and are viewable.
    Regards
    wimu
    Apr 2007
    Sundern
    It would certainly work at the laptop, but I think the guys from Index have meant something inserting the buttons.
    Registered Runde01's Avatar
    Jan 2006
    You can use the keys only in the DNC mode, Index C200/T200.
    Regards, Runde
    Apr 2007
    Sundern
    Ok, it explains everything.
    Thanks Runde01!
    majid1370's Avatar
    Apr 2017
    Default Re: C200 and entering of comments
    Hello to all
    I have an INDEX GSC42 S3TT / C200 TT.
    But there is a problem. After turning on and activating the hydraulics,
    everything is fine.
    By selecting NC1 & NC2, the X1 & Z1 & X2 & Z2 & C & Y1 axes are easily
    referenced and no error is observed.
    When the tool is called to the roller 1, the TURRET unclamps but does not move.
    After a few seconds at a very low speed that seems to be drift axis
    Spins and does not recognize the tool and continues to spin.
    And E8 & R0 & R5 errors are displayed.
    Can anyone help and guide me?
    Thank you
  7. #7
    majid1370's Avatar
    Apr 2017
    Hello to all
    everything is fine.
    When the tool is called to the revolver 1, the TURRET unlock but does not move.
    In addition, the x-axis and the roller have a servo motor
    They are common and the revolver does not have an instrument counting encoder and
    has three proximity switches 1S10 =E2.0 (revolver 1 locked) and 1S3 = E0.6 (revolver 1
    tooth pulse) and 1S1 =E1.0 ( position 1)
    and two The solenoid 3Y15 =A0.0 (revolver 1 lock )and 3Y14 = A0.1 (revolver 1 unlock )
    performs the lock and unlock operation ,
    I have no documentation of this machine.
    Thank you
