Blower for The Demon V8 - Page 7
Page 7 of 7 FirstFirst ... 4567
Results 73 to 80 of 80
Thread: Blower for The Demon V8
  1. #73
    Member stevehuckss396's Avatar
    Dec 2006
    Default Re: Blower for The Demon V8
    No holes. Air has to pass around the piston.
  2. #74
    Dec 2006
    A little update on the car.
    I couldn't make heads or tails of the gears as far as the exact placements of the cuts with the custom cutters. I fully understand the article and what is supposed to happen but the numbers didn't seem to work so i freakin winded it. I patched as much of the article together with the 3D cad and drew up the gears and eyeballed the shape of the teeth and did my own thing. After a few hours of adding a little here and taking off a little there I had a set of gears that were ready to "test". My pal was going to print the gears in ABS and pass them off to me to try. Couple days before I was ready his printer died. I really needed them printed on a "good" printer with good resolution. So I searched the web and found a place that could print ABS. Come to find out the set in ABS on a really good printer costs about 75 bucks plus shipping. After further snooping on the website i found they could 3D print in steel so I had to see what that would cost. 42 bucks in steel plus shipping so guess what I did. Well they are not that bad other than a bit of a rough finish but I figure I could run them in with a little diamond paste. They don't take kindly to drilling and threading. My mounting holes were printed into the part .005 under and I had to drill to size. Drill bit got hot real fast but it worked. Tap is still pissed at me but it did take a thread. Obviously not as nice as machined gears but cheap in my opinion. I still have an interference issue that I think some button head screws will clear up but other than that everything fit as planned.
  3. #75
    Dec 2006
    Put the final touches on the rear end. The center section was completed by cutting a clearance on the bottom so the mounting hardware could be inserted through the holes. The oil fill plug was drilled and tapped. The yoke was cross drilled so the Ujoint can be mounted. The entire thing was assembled complete for the first time. I also had a chance to make the front rims and the centers for the rear rims. I have 100 stainless screws on the way to assemble them.
  4. #76
    Gold Member LeeWay's Avatar
    Jun 2004
    What! No valve stems?
    Excellent work. I would not have thought of using sintered gears. I am only guessing that is the process they use when printing steel.
    Do you have a link to that source?
    May come in real handy at some point.
    It is coming together nicely. Work of art.
    Lee
  5. #77
    Dec 2006
    https://i.materialise.com/
    I think they are in belgium.
  6. #78
    Dec 2006
    Another weeks worth!
    I have finished the front struts. I still need to make the mounts for the top so stay tuned on that. Started on the pieces Saturday so there is 5 days, a couple hours a day. Need to sort out the top mount and make the hub so I can get the front wheels mounted.
  7. #79
    Dec 2006
    Well I finally have wheels on the front. I finished up the heim joints on the A arms and made the hubs. The brakes are bolted on for the first time and the tire is mounted. I am going to make a wheel spacer tomorrow to give a little more room between the rim and calipers.
  8. #80
    Dec 2006
    Well gentlemen, here's where I'm at on the little Chevy. The show is this weekend in Zanesville Ohio. If you can get there here is what you will see. I ran out of time and could not finish the rear wheels. I still need to make the bead locks.
