- Cant set tools Hyundai HIT 8s 840C
Setting up a new to me Hit 8s. Machine wasnt used for a while but everything seems to be in good working order. I did reload the parameters from the drive before using. Trying to set one turning tool (tool #1) to start with using the toolsetter. Following instructions in the manual and it seems to work (does enter data in the offsets) but the distance in X is off by 1.514" for the turning tool. Z offset is also way off but dont remember by how much. I tried to calibrate the tool eye probe as described in the manual by subtracting 1/2" of the difference between a measured part and the X display value to the X1022 parameter but it doesnt change anything related to the position display, just changes the offset numbers in the measurement tables. I do have the machine key switch set to EDIT COMM, and pretty sure Im doing the procedure correctly. Directly out of the HIt manual.
I also tried setting the tools using the tool offset/WCS calculator but that just generated different numbers in the control that werent seen in the position display in either Jog or MDI after a tool load command. Ive never seen a control that didnt display the offset position numbers when in any mode. Its like they cant be loaded for some reason.
Anyone know the trick to getting the offset correctly set? Or maybe the 840C cant display offsets unless called in a program?
Re: Cant set tools Hyundai HIT 8s 840C
After further head banging I see that if you program a move in MDI, say: T01D01 GO X.850 and make a cut the cut is spot on .850. Same with Z. This is after setting the tool using the tool eye using the same offset settings as the machine came with.
The position display still does not reflect the WCS offset position but:
I was able to go into Setting Data, general data, work coordinate display, it was set to no, you can reset to yes by pressing the select button. That makes the position display change to WCS if you're in MDI and program T01D01 G0 X Z. Still can't figure out if its possible to change the position to WCS in jog mode. Every other machine Ive ever run can switch between the two.
Seems incredibly dangerous to have a machine that can't display the WCS info. Both for using in manual mode and for setup. I guess it would be usable as it is in auto mode but seems like a really poor control implementation. Why would a company like Hyundai do this intentionally? To save few $ on licensing fees? Seems like they would potentially lose more on liability claims.
How are other Hyundai HIT users dealing with this?
I mean really, my 1983 Mori SL1 had changeable screens for MCS and WCS. You have to be pretty cheap to not include that feature. Anyone on this forum actually own/run these HIT lathes? After this I could see why there aren't many out there in use anymore.
Well, I sent an inquiry to Hyundai support and here's the response:
"Hello Mark
I got your information from the team at Hyundai Wia.
I have attached the response I received from the Service team at Hyundai.
Siemens 840C control is designed that way. There’s no way you can switch to WCS with Jog mode."
I guess that settles it, hyundai decided to be different from every other machine builder and not allow the machine to be used in JOG mode for anything useful. Oh well, should have asked them before I moved it into the shop. At least it was cheap. Hyundai HIT buyers beware!
I have Hyundai lathes with Siemens 840D control and have never ran the 840C control. On 840D, there is a button that togles back and forth between MCS and WCS. Have you tried pausing the program and switching to "JOG". on the 840D,this keeps the spindle turning and stays in WCS.
Not sure 840C supports this but thought I would toss it out there.
Yeah, I have an 840D on my DMC103V mill, this is ancient history compared to that one. I did try switching out of auto to jog but that only works if you're in a program, if you leave the program the WCS switches back to MCS. I like to have WCS in jog to touch up parts in collet chucks or setting up parts to check clearances.
I see that's its possible to switch between the "standard" interface and the Hyundai dumbed down one, Im wondering if its possible to change parameter 5001.01 when you're in standard? That parameter is supposed to enable WCS on regular 840C controls. The 840C on the Hyundai is missing/hiding that parameter entry.
I used this procedure below to switch out of Hyundai mode into standard interface to initialize my serial port. Ive got 4.8 OS. Scared to change anything else in standard and have the machine hang. If anyone has succeeded in changing the behavior of WCS by resetting it in standard please let me know.
110018 serial interface not initialized
Cause:
Interface incorrect or not parameterized.
Action / Procedure:
Select suitable interface file and re-parameterize.
Refer to the procedure MMC version 4.8 / version 4.9
How to check the MMC version 4.8 / version 4.9
• Press Menu Select
• Press Diagnosis
• Press Start-Up
Solution:
WHEN UPDATING TO VERSION 4.9, THE HYUNDAI USER INTERFACE IS NO LONGER
USED. THE FOLLOWING PROCEDURE SHOULD BE FOLLOWED TO DELETE AN MMC
FILE, WHICH WILL CAUSE SOME I/O INTERFACE PROBLEMS.
• Press Menu Select
• Press Diagnosis
• Press Password
• Press “1111”
• Press “Yellow” Input key
• Press Set
• Press Start-Up
• Press Backup
• Press Start
• ** Wait for control to boot to the time and date prompt.**
• Set Time and Date if necessary.
• Press “3” (DR DOS Shell)
• Enter Password - “mmc01_ss”
• Verify Password - “mmc01_ss”
• Type (CD MMC.001) press enter
• Type (CD USER.005) press enter
• Type (CD SERV.038) press enter
• Type (DEL GEZUORD.039) press enter
• Turn machine power off.
• Wait 20 seconds then power machine up.
• Your communications port should now operational.
WHEN UPDATING TO VERSION 4.8, IN THE EVENT OF ALARM CONDITIONS #10018 INTERFACE NOT INITIALIZED, THE HYUNDAI USER INTERFACE NEEDS TO BE RE-PARAMETERIZED.
• Press Menu Select
• Press Diagnosis
• Press Password. Input 1111,input, Press Set
• Press Start-up, Press Back-up
• Press Start and wait until the control boots to the time and date prompt.
• Set the time and press the yellow input key.
• Set the date and press the yellow input key.
• Select # 3 (DR DOS shell) from the menu.
• Enter the password. “MMC01_SS
• Verify password enter password again.
• Wait for the DR DOS prompt
• Type in UI and press enter.
• Select Standard Interface
• Wait for the message done.
• Power machine off. Wait 20 seconds, power back on and wait for control to boot.
• Press Menu Select
• Press Data I/O then Devices
• Select Standard and press Edit.
• Set device settings to 9600, RTS/CTS, 8,1, None and PC FORMAT.
• Press Store and then highlight Standard
• Press Selection.
• Press Data Output and use down arrow to highlight LOCAL.
• Go to your desktop or laptop computer and set it up to receive.
• On control press output start. Data should now transfer to your computer.
• To return to Hyundai interface continue with the following steps.
• Press Menu Select
• Press Diagnosis
• Press Password. Input 1111, input, Press Set
• Set the time and press the yellow input key, Set the date and press the input key.
• Enter the password. “MMC01_SS.
• Select Hyundai Interface, Wait for the message done
• Machine is now back in Hyundai Interface Mode.
- You may not post replies
- You may not edit your posts
Forum Rules
