Need Help! kiaturn15 AL-60 alarm???!!!!
Results 1 to 6 of 6
Thread: kiaturn15 AL-60 alarm???!!!!
    Member fettersp's Avatar
    Jan 2020
    Default kiaturn15 AL-60 alarm???!!!!
    I have a kia turn-15 with fanuc oi-t controller.
    The machine was crashed yesterday and started with a z axis torque alarm. I got that freed but now have an al-60 index turret power off alarm.
    The procedure im following was written down by my father and is not working.
    1. change parameter 0011 to 00000001
    2 turn off and on
    3.set k5 bit to 1
    4. push select, feed hold, and spindle stop.
    5. turn turret by hand till arrows match up.
    6. push call/bz off
    7. set k5 bit to 0
    8 push spindle stop, select, and feed hold
    9. change para 0011 back to original
    10. power off and on
    this is not working and im not sure what to do right now
    Member OkumaWiz's Avatar
    Apr 2009
    Default Re: kiaturn15 AL-60 alarm???!!!!
    I think you are on the right track for re-teaching the turret, but I think there may be something else going on based on your alarm. Is the drive unit actually powered on? You may have either a tripped circuit breaker or else may need to power down, wait a few minutes and reboot after the caps discharge to allow the drive to reset. Ill attach a procedure for the reteach, but I think you basically have it right.
    Best regards,
    Attached Thumbnails Attached Thumbnails kiaturn15 AL-60 alarm???!!!!-2100sy-turret-home-position-pdf
    Experience is what you get just after you needed it.
    Jan 2020
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    how do you tell if the driver unit is powered on?
    I checked the back of the machine and there are only 4 breakers which none of them are tripped.
    im currently waiting for the capacitors to discharge to see if the works
    Jan 2020
    The waiting did not get rid of the al 60 code that its throwing
    Jan 2020
    So I don't what happen but what I did in my confusion I spun the turret about 20 or more times and got the turret adjustment mode message. after that it is running
    Apr 2009
    Based on your description you may have a turret encoder starting to go bad so it’s something to watch or inspect.
    You should have indicator lights or led numerical displays on your drive units that show status. It’s a good idea to take a picture now that it’s running right to document what they should look like. That way when something happens you can compare and see if anything has changed.
    Glad to hear you’re back in business!
    Best regards,
