Hyundai Kia SKT 200 Alarms
Results 1 to 2 of 2
Thread: Hyundai Kia SKT 200 Alarms
    RubenCarner's Avatar
    May 2020
    Default Hyundai Kia SKT 200 Alarms
    Hi everyone.
    I hope someone here can guide me on the right direction troubleshooting this machine.
    Got hold of this machine a few months back and it being shoot down and i have been spending much time cleaning it and troubleshooting alarms.
    Initially was a lot of FANs related alarms (701, 609, etc ) which i manage to clear by just degreasing and cleaning the fans.
    Now i am having a different kind of alarms.
    when i try to MDI command code M03 S1000 the control posts the following alarm : al-32 -center position ng
    If i try to run the spindle in Jog Mode using the dual keys combination the control also outputs the same alarm.
    With the Turret have slight different situation.
    In jog mode i can Clamp/ unclamp/ rotate the turret, but if i comand with MDI it gives the following error : al-66 turret index cond. ng
    I understand this might be turret reference procedure to follow as i can see the tool called and the tool in spindle are not coincident.
    Al-32 points to some electronic card replacement, however i would like to have other opinions from folks here.
    I am not very experience with maintenance, however i would like to give it a shoot before service call.
    Thank you in advance.
    Jan 2013
    germany
    Default Re: Hyundai Kia SKT 200 Alarms
    Quote Originally Posted by RubenCarner View Post
    it means your Tailstock Quill is not retracted, or you need to adjust tailstock sensor.
