Are you able to move the B-axis with the Paul handle? Or jog it? It also appears to be moving quite rapidly for a zero move if you slow the rapid rate down does it still want to jump like that? If you can move it with the Pulse handle or jog it the the axis should be ok. If not, you still have drive work to do. If they can move OK then you probably have a parameter issue.
