Problem Alarm no SKT21
Results 1 to 3 of 3
Thread: Alarm no SKT21
    *Registered User* Millerdiego's Avatar
    Jun 2018
    Default Alarm no SKT21
    Hello.
    I'm with him, the photo alarm. AL-32 center point ng.
    the lathe does everything except turn the spindle. does not run in the automatic mode.
    Does anyone know how to solve ??
    thank you.
    Attached Thumbnails Attached Thumbnails Alarm no SKT21-img-20180617-wa0007-jpg
    Member OkumaWiz's Avatar
    Apr 2009
    Default Re: Alarm no SKT21
    Does your machine have the tail stock quill confirmation switches? They may be out of position or you may need to bypass them with M-code in order to turn on the spindle with the quill retracted.
    Experience is what you get just after you needed it.
    May 2016
    United Kingdom
    AL-32 Abnormality in RAM internal to LSI for serial data transfer
    Did you try and load a program as I think your memory requires clearing
    CNCELOS's Avatar
    Nov 2018
    Hi
    I understand this thread is one year old, but have you solved your problem?
    I have a SKT200 2007 Oi with the same alarm.
    When i try to MDI ex: M03S1000 it clicks and pops the same Al.
    rgds
Alarm no SKT21
Alarm no SKT21
