- Need Help!- io setting fanuc robot with hypertherm source
I am using powermax 65 spurce with Fanuc 100ic/8l robot
need help for setting
cpc out put data connected to Analog input module(AAD04A)
divider set to 50:1(hypertherm)
on tech pendant weld IO setting (it shows graph AI-weld voltage)AI(min-max)--i set min-0 and max -10V and weld voltage 139v max and 0v minimum is it right ?
or weld voltage max will be 139/50=2.78v max and min-0 ? or max 395v-min 0v..?
please suggest as height controll with AVC in robot can not be optimised.
please refer picture of ipendant.
upowermax robotics/cnc interface-image-jpeg
- You may not post replies
- You may not edit your posts
Forum Rules
