To control HPR machines fully, you will need a combination of CAM and control software. This is required since the features like True Hole need to be activated at Gcode level. For example, during cornering, it can lower the amperage automatically.
You can try to use the serial command with PC or arduino control software, and use sheetcam rule to post additional gcode required
