Need Help! Old esab CNC table
Results 1 to 5 of 5
Thread: Old esab CNC table
    Member Dem1's Avatar
    Sep 2019
    Default Old esab CNC table
    Hi all just bought a esab CNC table
    Model number , combirex CXD-P 4000
    at handy money
    It's that old it runs on floppy discs
    Who would advise ripping all the control gear out and replace with modern gear
    I think it runs on servo motors
    I only ever worked with steppers on our table, so not sure how servo works
    I brought it for the factor that it's a ht2000 hypertherm unit on it, and it would suit us as we need to cut heavier stuff faster 20-25mm
    I had a homemade Mach 3 table running a 120Amp thermal dynamics, this esab table is slot bigger 12ft X 30ft which would also suit us better
    Apr 2013
    Default Re: Old esab CNC table
    I converted an old Esab DuctCutter to Mach3, and it wasn't that bad, the Vision controller on it was not very user friendly, and I wanted rid of the floating head. I didn't have a lot of luck with the servos and original drives, so finally ended up going to geckos. If I ever need to upgrade motors, or have a motion controller issue, I'll likely switch to Clearpath Servos to simplify the system a bit.
    Sep 2019
    Thanks for reply
    I'll check them out
    UOTE=wyofreeride;2325076]I converted an old Esab DuctCutter to Mach3, and it wasn't that bad, the Vision controller on it was not very user friendly, and I wanted rid of the floating head. I didn't have a lot of luck with the servos and original drives, so finally ended up going to geckos. If I ever need to upgrade motors, or have a motion controller issue, I'll likely switch to Clearpath Servos to simplify the system a bit.[/QUOTE]
    Jan 2013
    England
    I would try Techserv Cutting Systems http://techserv.co.uk
    They make some really good machines (I know because I have had two of them).
    They use their own controller which is really easy to use and they do a lot of retro fitting to machines like yours, if fact I believe there are a couple of videos on YouTube showing such installations.
    Member cowleym's Avatar
    Oct 2007
    UK
    Hi Simon, thanks for the mention.
    Cheers
    Mike
    Techserv
Old esab CNC table
Old esab CNC table
Old esab CNC table
