You probably could put a quick disconnect on a 30, though I have never done this.....so I cannot offer advice. Keep in mind that there is the possibility of open circuit DC voltage of around 300, which can be lethal! There also are trigger wires and parts in place sensor switch wiring in the torch lead. The Powermax30 is not designed for machine cutting....however there are a few using it that way. Good luck, best regards, Jim Colt Hypertherm
