Hydraulic Motor
Results 1 to 3 of 3
Thread: Hydraulic Motor
    Member Chris12345678's Avatar
    May 2020
    Default Hydraulic Motor
    We have a hydraulic motor on an injection molding machine. It is a hydraulic driven motor, not a hydraulic pump.
    The most has thrown off the rings that connect the pistons. There is damage to the rings but nothing else has the slightest mark on it.
    We have been told that we need to buy a new motor at a cost of several thousand pounds.
    Surely we can just get these rings made rather than buy a whole new motor?
    Does anyone have any thoughts please?
    Nov 2013
    Default Re: Hydraulic Motor
    you might try some of the automotive Engine reconditioners. Some of them will make rings to suit.
    My understanding is that they are turned from white cast iron tubes. I further understand it is the 'barrel' grind
    that is applied that determines its suitability as a compression ring.
    Craig
    Dec 2013
    Maybe you can have new rings made. Without knowing more about the motor it is difficult to say how to proceed. I'm surprised that there are no repair parts available for that motor.
    Jim Dawson
    Sandy, Oregon, USA
Hydraulic Motor
Hydraulic Motor
