Check oil levels....
My RG 80 Press Brake will not go above 20 tons on a bend. I get no alarms or indication of problem. Has anyone had this issue?
- Need Help!- Amada PRESS BRAKE HFT 220-3
- Need Help!- Amada Press Brake
- Need Help!- Amada brake press controller nc9 r
- Amada Press Brake Controller problem
Check the relief valve on the left end. Also the adjusting bolt that pushes the rod into the distribution valve might have worked loose.
Hope this helps,
Tom
Mister NCT has suggested just what to do, The rod that connects your bar pedal to the valve rides on a bolt with a jam nut. You only want to take up the play, so you should still be able to spin the rod with two fingers.
The problem was the relief valve. Thank you for your help!!
