Build Thread need help with new build and Airsoft Mach 4 board
Results 1 to 6 of 6
Thread: need help with new build and Airsoft Mach 4 board
    Activation process itsJustme's Avatar
    Nov 2018
    Default need help with new build and Airsoft Mach 4 board
    this build has a liitle bit of everything going on with it but would need some input, this is the third machine build I have done the first 2 were the very basic build this and plug theis wire in that sopt and it should all run, But this one is a little more in depth especially the Card!
    I am build a machine that is combining parts from Makerstore and yuyong industries, and want to run this with MACH 4, i ALREAD HAVE THE SOFTWARE ALONG WITH CONTROL CARD FROM AIRSOFT USB FOR MACH4, i HAVE NEVER WIRED ONE OF THOSE CARDS UP AND IT SEEMS SOMEWHAT challenging but it just may be me another gentalman on a FB site was cheering me on and trying to convice me that it is the same as the other comtrollers that I did on my 2 entry level machines.
    Is there a clear concise schematic that would take me through it step by step? I will also be running closed loop steppers and have the airsoft Mach 4 control card?
    Nov 2013
    Default Re: need help with new build and Airsoft Mach 4 board
    I have used Mach4 for eight years and am pretty familiar with all the manufacturers of different Mach4 ready motion controllers but I've never heard of one called 'Airsoft'.
    Please post a picture of it, and who makes it?
    Craig
    Oct 2009
    Maybe he meant Artsoft?
    Nov 2013
    well yes I considered that but Artsoft do not produce a motion control board at all, they provide Mach4 software only. Yet OP definitely refers to a piece of hardware.
    Craig
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Perhaps --perhaps-- there is a word left out, and what he really meant was: "airsoft approved Mach 4 control card".
    Where did I get that idea? See post #1 in this thread: https://www.machsupport.com/forum/in...0610#msg270610
    Nov 2013
    I suspect you are right, he has an RnR motion board, which are big trouble. They work with Mach3 , mostly or sometimes, but they do not work with Mach4 at all.
    Craig
