- Need Help!- okuma lb15 wilt osp5000 moves only in one direction
Dear friends,
I have a cnc okuma lb15 with osp5000 controller, when i try to jog the cnc the z axes moves in both directions but the x axes moves only in one direction.
the machine is not showing any errors on the controller or on the driver, but the x axes only moves in the negative direction?
what may cause this and how can i fix it
Re: okuma lb15 wilt osp5000 moves only in one direction
Hi. We have the same problem. Were you able to solve this?
- You may not post replies
- You may not edit your posts
Forum Rules
