- Would appreciate if someone told me what this is?
Re: Would appreciate if someone told me what this is?
Hi Martin
If you can't ID it, you can trace it yourself.
Find the DB25 (LPT) pins that you want to use as an input to your software . Then, for each, use a combination of eyes, chip datasheets and a multimeter checking for continuity to trace what's feeding that input. It's not as easy as reading a manual but it's not terribly difficult either.
Bad news Martijn - I could only find reference to the manufacturer on archive.org - their website was defunct as of 2011 - the only link I could find that was pertinent to the board you've got is here, and it's not exactly informative.
From what I can tell, it looks like ports 2 and 3 cover low voltage I/O - they seem to be completely optoisolated, but I'd still make a point of tracing out all the connections first. I would guess that pins 2,3,4 and 5 are the relevant pins on port 2, with pins 6-9 being ground, and pins 3,4 and 5 are the ones to trace on port 3, with pins 6-9 being VCC.
It'd be worth looking up the datasheet of what I'm assuming are the optoisolators next to the DB9 ports, because that'll tell you whether or not the port's intended for input or output.
- You may not post replies
- You may not edit your posts
Forum Rules
