What speeds are you getting with your EZ driver board?
Results 1 to 4 of 4
Thread: What speeds are you getting with your EZ driver board?
    Nov 2005
    Default What speeds are you getting with your EZ driver board?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: What speeds are you getting with your EZ driver board?
    What size motors?
    If I recall, when a lot of people were building Joes 2006 machine, they were getting about 100ipm with 1/2-10 single start acme, and 300oz motors. That's about 1000 rpm at the motor.
    UCCNC 2017 Screenset
    Member WoodWorkerB's Avatar
    Feb 2011
    I have
    - HobbyCNC Pro (same driver chips).
    - 1/4-20 drive screw
    - 36V unregulated linear power supply
    - 300oz in motors
    - 1/2 microstepping
    I can push it to 40ipm, but that's pretty much it. For milling, I will go to 38 ipm max, typically 30 - 35 (material dependent, of course)
    I only have a home-made DIY hobby machine, and for a 20 thread-per-inch drive screw, 38 ipm is pretty respectable.
    You can do the math to figure out the steps per second.
    BrianV
    WoodWorkerB
    WoodWorkerB.com
    Sep 2006
    I have a HobbyCNC Pro and a 48V power supply. I forget what the microstepping is set to, but doubt that it would limit the max speed as long as the PC can keep up. I am using a 10 year old XP computer with a parallel port.
    My original router build had 10TPI ACME screws driven by 425oz motors. I could sometimes get 60ipm and would typically cut at 30-40ipm. Every once in a while it will stall and ruin the job.
    I switched to Ebay rolled ballscrews with 0.5cm threads, so effectively 5.08TPI. I could easily get over 100ipm and never felt the need to check the maximum speed. I usually cut at 60ipm and have never stalled the motors.
    Steve
