Need Help! Estop and Light Curtain
Results 1 to 5 of 5
Thread: Estop and Light Curtain
    Member Swager's Avatar
    Feb 2022
    Post Estop and Light Curtain
    On my Omni CNC, when the OP breaks the light curtain or Hits the E Stop the Z axis crashes down 3-4 inches. Everything looks to be in tact electrically. What am I missing?
    Dec 2013
    Default Re: Estop and Light Curtain
    Bad Z brake maybe?
    Jim Dawson
    Sandy, Oregon, USA
    Feb 2022
    That is my first assumption after getting panels opened up. Also might replace the cylinder why I have it all open. Hasn't been cleaned in years it looks like.
    Dec 2013
    If it has a counterbalance cylinder, then that might be the problem.
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2003
    I have seen this on lathes with heavy vertical X axis where the hydraulic stop valve has failed.
    I should add, this was on the counter balance hydraulics.
