Looking for online CNC service that does thin wall (<1mm) copper
Results 1 to 16 of 16
Thread: Looking for online CNC service that does thin wall (<1mm) copper
    Member Tubbstcg's Avatar
    Apr 2019
    Default Looking for online CNC service that does thin wall (<1mm) copper
    I am working on a small electronics prototype where I added some fins to the heatsink for better heat dissipation. The fins were 0.5mm thick and the first service I contacted said their process cant do walls that narrow and that I should bring them up to 1mm and resubmit my design. A lot of the online services I have found said they can go down to 0.5mm in thickness but want the average wall thickness to be 1mm. The problem with that is my project is so small the walls are currently set at 1mm. So I am hoping to find a service that is either okay with the 0.5mm fin design as is or would be willing to meet me somewhere in the middle and not force me to bring it all the way up to the full 1mm fins. If anyone has any ideas for some online services to look into that would be great of just some general advice.
    Thanks in advanced, Jonathan
    Aug 2014
    Default Re: Looking for online CNC service that does thin wall (<1mm) copper
    Have you considered folding the fins from 0.5mm sheet then soldering them to the heatsink base ?
    Member mactec54's Avatar
    Jan 2005
    Quote Originally Posted by Tubbstcg View Post
    Do you have a drawing if the fins are not to tall that is not difficult to machine, and if it was you could rough machine then use an EDM to do the finished size
    You may also be able to wire EDM where it can't be machined
    Mactec54
    Jan 2005
    Quote Originally Posted by Zorbit View Post
    That would be a very poor heatsink, the joint weld would have to be done with a laser to have any chance of a reasonable heat transfer
    Mactec54
    Aug 2014
    Not welded, silver soldered. Silver has better thermal conductivity than copper.
    Jan 2005
    In your post you said to solder them to the heatsink!!
    It would be welded if it was done with a laser is what I posted
    The problem with your answer is silver solder solder is not 100% silver so the thermal conductivity of the joint would not be better than copper
    AG=Silver 429 only silver
    CU=Copper 401
    Pure silver wins, but no body is going to use pure silver for a joint like this
    The average silver solder rod starts at only 5% silver so to get a 95% silver content rod the cost per rod would put this to rest very quickly and it still would not have the same thermal as copper
    Mactec54
  7. #7
    Aug 2014
    Silver solder is commonly used here in the UK, EasyFlo is a popular brand. Typically 55% silver, 15% copper, rest cadmium and zinc. People have been making heat exchangers and radiators with it for 100 years. I'm sure it would be cheaper than EDM.
    I thought this was for a prototype anyway, if not then perhaps the best way it to find someone who can skive copper.
  8. #8
    Jan 2005
    It would be easy to machine if the fins are not to deep, these copper parts in the attach photo I machined and are less then .5mm thick they where machined from solid
    It is used around the world and there are lots of different application's where it can be used, Easy-Flo is a better name for it as it is not a solder 55% silver that would be expensive
    Silver Soldering Vs. Soldering
    Soldering, or soft soldering, is any joining of metals using a filler metal that melts below 840°F. Note that the melting points for silver soldering are considerably higher. “Silver solder” is a misnomer and is a form of brazing. It is sometimes referred to as “silver braze.” The American Welding Society discourages the term “silver solder.”
    Attached Thumbnails Attached Thumbnails Looking for online CNC service that does thin wall (&lt;1mm) copper-melt-temperature-2-png   Looking for online CNC service that does thin wall (&lt;1mm) copper-hpim3221-jpg
    Mactec54
  9. #9
    Aug 2014
    UK terms are a bit different. Brazing is usually referring to a joint where brass is the filler and is applied like a welding rod, Silver Soldering is usually done with pre-shaped shims or rings of solder plus flux placed into or onto a joint and then the job heated with a torch or in an oven. It's pretty cheap, the gaps between parts are extremely small.
    It makes sense to standardise names, we already use AWS designations for welding rods, so we'll probably stop calling it silver soldering soon too. We're keeping Aluminium though ;-)
  10. #10
  11. #11
    Jan 2005
    A brazed joint is anything that a torch is used for, that requires over 840 Degree melt temperature
    I think it will always be called silver solder even though it is not a solder, I'm an experienced user and always have it on hand along with Sil-Fos for copper to copper joints
    There is some good ideas in those links, slots could be milled and then shrink fit the fins in place would most likely work for a proto types, he has not posted a drawing so we have no idea of what is really needed
    Mactec54
  12. #12
    Jun 2018
    on my feet
    I'm willing the bet that you'd be able to find an extrusion that will fit the bill , unless you've got some funky shapes to the heatsink , I've machined many heatsinks from solid , or finish machined extrusions . If you can find an extrusion that fit your needs , then there will be a big cost savings in having the rest finish machined on the pockets , drill/tapped holes etc
  13. #13
    Jan 2005
    Quote Originally Posted by metalmayhem View Post
    Aluminum extruded heat sinks are everywhere, Copper as an extruded heat sink, not so many choices
    Mactec54
  14. #14
    Jun 2018
    on my feet
    copper ya not so much , I missed seeing copper .
  15. #15
    May 2015
    To me this is a classic case of a design meeting the real world. Some things designed on a computer cannot be built. Listen to the vendors and revise your design. But surely an appropriate heat sink can be purchased without the need for machining.
    Rod Webster
    www.vmn.com.au
  16. #16
    Mar 2008
    .5 mm heatsink fins? Is that even enough mass to move the heat? I seriously doubt youll find any reliable way to supply this as a machined feature and if so, it will be very expensive.
