A circle, a simple circle. How hard can it be?
Results 1 to 12 of 12
Thread: A circle, a simple circle. How hard can it be?
    Aug 2017
    Switzerland
    Default A circle, a simple circle. How hard can it be?
    I'm new to CNC having built a 2-axis plotter driven by Arduino, CNC-Shield and GRBL 1.1.
    I can draw a square.
    I now want to draw a circle and have failed miserably for days.
    I have googled on and off for about a week now and looked at dozens of examples. Not one of them does a circle. Not on my machine nor in any of about 5 different simulators I've tried. At best a limp arc, at worst straight lines or nothing.
    Come on.
    A circle.
    Could someone post the GCode to do say a circle centered at X=0,Y=0 with radius 5cm?
    Since I now believe it is impossible. Please check your work here:
    GCode Simulator
    or here:
    https://nraynaud.github.io/webgcode/
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: A circle, a simple circle. How hard can it be?
    G0 X0 Y5
    G2 X0 Y5 I0 J-5
    Doesn't work in the first simulator you linked, but works in the second one.
    UCCNC 2017 Screenset
    Member handlewanker's Avatar
    Sep 2006
    Hi, if you took the time to learn G code all will be revealed, but you gotta be in it to win it.
    Ian.
    Aug 2017
    Switzerland
    Quote Originally Posted by ger21 View Post
    G0 X0 Y5
    G2 X0 Y5 I0 J-5
    Yeah... doesn't work on my machine (running GRBL).
    The first command works but the circle doesn't and I get:
    error 33 for G2 X0 Y5 I0 J-5
    Aug 2017
    Switzerland
    OK, the circle code works in UniversalGCodeSender but not in GrblController 3.6.1
    I thought these programs just send GCodes to the machine so how can they get different results??
    Mar 2003
    Shelby Township
    Different controls read g-codes differently.
    I think that GRBl doesn't allow full circles, only partial arcs.
  7. #7
    Aug 2017
    Switzerland
    But GRBL is on my Arduino - I'm just switching between different PC software which both send "G2 X0 Y2 I0 J-2"
  8. #8
    Mar 2003
    Shelby Township
    I think that Universal G Code Sender breaks the circle up, and sends multiple arcs to GRBL.
  9. #9
    Aug 2017
    Switzerland
    I think I see what's happening. If you're in relative mode (G91) you can't draw circles.
    FAIL:
    >>> G91
    >>> F100
    >>> G0 X0 Y2
    >>> G2 X0 Y2 I0 J-2
    ok
    ok
    ok
    error:33
    SUCCESS
    >>> F100
    >>> G0 X0 Y2
    >>> G2 X0 Y2 I0 J-2
    ok
    Is there any way to just draw a circle centered from wherever you are?
  10. #10
    Mar 2003
    Shelby Township
    You can, but the code is different.
    G91
    G0 X0 Y2
    G2 X0 Y0 I0 J-2
  11. #11
    Member BobJohnson's Avatar
    Jul 2019
    it's really hard for me
  12. #12
    Jul 2019
    Madrid
    Hello, in this article it is very well explained (it is in Spanish but you can translate it) https://www.geniolandia.com/13120889...-con-codigos-g
