- Hitachi Seiki Alarm Help!
It is a HItachi Seiki VK55II VMC with Seicos MIII control. There was a power outage. Now at power up there is alarm (2AC5)APC Slave Fuse Trip. The description of the alarm in the book says Fuse Of APC Slave Unit Has Been Blown. I can not seem to find anything on this. Has anyone seen this? Thanks for your help!!
I have purches a hitachi seiki HC400 machine.
I need your support.
Now have a problem in the plc (M16 II).
There is 2 alarms are coming.
1. SUM CHECK ERROR.
2. BATTERY ALARM.
Please help us for clear this alarms.
I checked the power supply in PLC. (+15V, -15V, 5V 24V and Battery Volt) it's all ok.
But the alarm does not clear.
Please Help Us.
Thanks & regards,
It has been awhile but according to my old notes you need to do the following for the SUM CHECK error.
1. Press F1(SEQUENCE) ->Press F2(DATASET) -> Press F4(TABLE) -> You will see “Constance Byte Table 1
2. Type 0 0 (in the 1. 00) -> Press INPUT -> You will see Parameter Write Enable SW On
3. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
4. Press F6(END). -> You will see Write Enable SW Off
5. Turn off WRITE ENABLE SW
6. Press F6(END) -> Press F1(SEQUENCE) ->Press F3(PROGRAM) -> You will see Parameter Write Enable SW On
7. Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel
8. You will see top line of ladder automatically
9. Press F2(ALTER) -> You will see ___(Cursor) on screen.
10. Press F4(STORE) -> Press INPUT.
11. Press F6(END) -> You will see Write Enable SW Off
14. Turn off WRITE ENABLE SW
15. Turn off NC power -> Turn on NC power
This may or may not work as I said before it has been a long time and some things may need to be done in different sequences. Give it a try and let me know if it works.
Good luck,
Stevo
Thaks. I will check my machine and get back to you.
Hello,
I tried my machine as per your instruction. After the step no 7 Turn on WRITE ENABLE SW that is on MICON16-2 board in control panel. it will ask key ward please____. I don't the key ward please support for the key ward.
Thanks once again.
It should not be asking you for a password. IIRC this happened to someone else that I was helping and they had to do the procedure a few times before it would take and not ask for a password.
Stevo
Hello Now I lock an other alarm
Power supply down +15V.
Power supply down -15V.
Please help me.
Thanks.
Re: Hitachi Seiki Alarm Help!
hi I was hoping somebody could help me with my alarm code on my Hitachi hg 800. I was doing a automatic pallet change m60 when half way through the cycle the e stop triggered results in power to cut out and unable to recover pallet to table side of the machine, ive tried the sw1 switch maintenance mode but it wont let me do anything because off another cc alarm in red that states parameter write enabled please can some one point me in write direction also how to solve these two problems thanks
Hi, I have a Hitachi Siki model h cut 230 m. Alloacted page is limited. How can I increase it?
- You may not post replies
- You may not edit your posts
Forum Rules
