Without looking through the ladder, my first guess would be that the tool isn't unclamping and that is raising the rest of the alarm states. Will the tool manually unclamp?
Hitachi Seiki VS50 SEICOS E18M. When tool change start the x axis goes to twin arm and catches the tool and
[2047] D404.7 LS Tool unclamp alarm followed by [2114] D411.4 ATC cam stop command LS detect error
[2115] D411.5 ATC cam origin detect error
[2185] D418.5 need ATC origin [maintenance mode]
I've checked all the limit switches and sensor signals in PMC diagnostics. I couldn't come to a solution, kindly help.
Mail : mathalaikanna@gmail.com
Problem solved. ATC ARM motor inverter output cables loose contact.
Mathalai Kanna
