If you send me
Your email I can show you how mines wired up will with a switch as a bypass.
Hello, I have an issue with finding parameters on disconnecting Breuning IRCO — ILS bar feeder from Hitachi Seiki HT 20S II (yasnac lx-3). We bought used lathe and it was coming with bar feeder, we don't need the bar feeder and trying to remove it from Hitachi system but cannot find where. Please help
If you send me
rinatKh89@outlook.com Hi! Here's my mail. Thank you in advance for your help!
As written above, it may need a blanking on plug to simulate the safety signals from the bar feed. Ie. A harting type plug with link wires inside plugged into the machine barfeed interface socket, then usually you can switch off the barfeed by a switch on the panel or an option parameter bit.
If it was cobbled together by a third party user, you will need a wiring diagram. Barfeed machines have a hollow spindle and clamp cylinder, where chuckers often don't. A 3 jaw chuck signal is opposite to a collet chuck, some machines also have a toggle switch to reverse this function.
Thank you for your answer! I managed to make it like a fork as you said and turn off the barfeeder. Only now the M commands for clamping / unclamping the chuck do not work. Maybe I didn't install all the plugs. Can you specify switch on the panel or an option parameter bit to disable the barfeeder?
