- Need Help!- Need Help
Need Help
Has anyone had this problem, working on a Yama Seiki GS-465 with a Fanuc Ot-I,
Lost the parameters due to dead battery, reloaded parameters, set turret position using PPM 11 and K 7.5 procedure and jogged the turret to #1 tool, when I power down and power up, the green light on the turret button is good all the green lights on the turret amp are good, but when I try to change tools, the turret just clamps and unclamps without indexing and I receive a 2918 Turret Run Alarm, I have tried to zero return the turret using the instructions in the book, still cannot get the turret to index, has anyone had this problem,
- You may not post replies
- You may not edit your posts
Forum Rules
