- Va-40 atc problem
Va-40 atc problem
Ok machine was ok....then a cable backed off the mother board, didn't have retaining screws, the only cable that doesnt...why???
All seemed ok, however now the atc is off by one number.
If i ask for tool 1 to be indexed i get 2 and likewise for all
I did reprogram using 40 sequence that pot one has tool 1 etc for all 26.
The 46 imp 9 reset doesn't seem to do anything??
Anyone know about these ol girls???
I do have all the Hitachi books but have not found any solution ....
Re: Va-40 atc problem
OK problem solved
In one of the books was the reset procedure, just wasnt in the book I thought it should have been.
If anyone needs this info I will be glad to share it.
The PLC must be able to report 45 H ready or it will not work
- Va-40 atc problem
- You may not post replies
- You may not edit your posts
Forum Rules
